running issue please help
caprirs1
engine starts and stalls but will run with mass air unplugged 92 b2200 fuel injected
X
xxchromeghostxx
replace the mass air flow obviously. if that's unplugged and it run right there is your problem why ask?
caprirs1
ok i have a spare mass air that i tried and it also does the same thing with that any other thoughts
fdugn545's avatar
fdugn545
Maybe an ecu issue? Or maybe wiring problems? Idk I have a carbed truck.
Fred
Sent from Samsung Galaxy S3 using Tapatalk 2
caprirs1
ok heres some more info i scanned my truck last night and it spit out a code 17 any help would be much appreciated
itizmyne's avatar
itizmyne
Codes
And more codes
" target="_blank
Feedback systems so then here they say that fault means a bad ECM
" target="_blank
spacemonkee23's avatar
spacemonkee23
Sounds like you have a bad ECM
Here is a thread that has a lot of info on bad ECM and repars...
The thread says 2.6 but it is the same issue with the 2.2
I would pull the ECM out and open it up to see if there are any leaking capacitors, its almost a guarantee that there will be corrosion from capacitor acid.
I have a 92 2.2 EFI also. I'm pretty sure my hesitation when its cold is from the ECM too. Haven't checked though, take some pics of it and Good luck!
spacemonkee23
I have a 92 2.2 EFI also. I'm pretty sure my hesitation when its cold is from the ECM too. Haven't checked though, Good luck!
