lowered my 92 b2600i 3" blocks mono leaf problems in the front
F
oldskool92
So I lowered my b2600 I. the rear I'm bottoming out on my rearrnd to fix do I need to c notch it? Now as for my torsion bars is it better to jack it up the loosing the screws or will the truck is on the ground. I tried lowering it while on the ground and its being a paid in the ass need help what to do!!?
customkev89's avatar
customkev89
might not be the same but i figured i would try to help i have a 89 mazda b2200 its mono leafed in the rear and what typically happens to me when i slam the rear of mini trucks is the stock shock bottoms out before it hits the frame, thats mono leafed no blocks and 18" wheels w/ anywhere from a 35-40 series tire roughly a 25" tire. so i usually change the shock out but you could deff. c notch the frame for extra clearance if its still bottoming out on shorter shocks, as for the torsion bars i never really had a problem lowering w/ the weight of the vehicle on the ground maybe spray a little wd-40 if the threads are rusty or gunked up hope this helps
oldskool92
Yeah its kling my arm might need some wd40 but now my anti-lock has come on because I lowered it is this a big problem I know it has to do with the abs brakes what you thibk ?
91extcab's avatar
91extcab
Lowering it doesn't affect the abs, but since the abs in these trucks is rear wheel abs only, i removed mine from my 2600i. Stock shocks is the rear will not bottom out before the axle hits the frame because the shock mounting distances don't change with blocks, only the point where the rear end connects to the leaf springs. That distance will change a little with mono leaf, overload and 3in blocks, but not enough to make them bottom out before the axle will come into contact with the frame. A notch would help, and an in frame small c notch would solve axle slap. I had the same issue with my truck, i however put in a set of air shocks to help with ride quality. That was before i z'd behind the cab, went back to a full leaf set with load carrying shocks. I also have 3in blocks even with the z, and a set of pinion angle shims.
On an abs note, you can remove the abs by getting rid of the actuator on the frame, passenger side, above the rear axle, and by removing the computer from under the drivers seat. I removed my abs out of necessity when i swapped to a b2200 rear end which didn't have the abs sensor like the 2600i rear had.
Oldskool, I'm gonna send you a pm with my tablet phone number, feel free to text me with questions. I'm one of the few guys with 2600i knowledge, and i don't know as much as some, but do know more than most with what I've been thru with having mine as a daily driver for 5+ years, and 120,000+ miles driven by me, mine currently has ~326000 miles, original motor/trans
