Finally found one....advice?
b-easy
Hey guys, been looking for a while, specifically for a B2600i SE-5 in good condish...
check this link---> " target="_blank" target="_blank
carfax---> " target="_blank
What do you guys think? What should I look for when I see it tomorrow?
X
xxchromeghostxx
In cali look for and make sure all emissions are intact, of course you should know this, but just saying. Also look for frame damage lots 4x4 guys like sand duning out there. And rocks are hidden all through them. Just cause carfax wasnt reported diesnt mean it didnt happen.
Now the most important part is take the bubble hood off and trade for my hood lmao j/k. And with that many miles id have it conpression checked on all cylinders before i buy it. You could be looking into a possible piston ring replacement.
Cusser's avatar
Cusser
1989 B2600i has some one-year-only electronic parts, so make sure it runs good.
Also, if it has AC, make sure that works OK. And of course, run through the gears and the 4WD too. Check the 4WD drive axle boots up front.
dan woodland's avatar
dan woodland
Check all coolant hoses and for signs of overheating... Check the oil and coolant for the other... mixed oil and coolant.
Have them not start it until you get there so you can hear it run from cold to operation temp.
Ask if the ECU has been serviced. If not it may cost you a couple hun to fix.
If she runs smooth and doesn't swep fluids and as cusser said other one-offs work correctly.
Look like it was taken care of. Good luck, let us know. Dan
