For the guys running GM 6 lugs
jayking
Quick Question. Got the 17's today, looking at tires! No mods done, All stock! What size tires can I run? Without hitting bottom of fender ? 87 B2200 2wd Grinding tabs in A.M.
alittlelow's avatar
alittlelow
I guess that depends on your setup are u static or on bags if bags you can wrap them with a set of 205/40/17 but if you are static it all depends on how low u r
Sent from my Desire HD using Tapatalk 2
jayking
ALL STOCK AS STATED!!! No Drop
alittlelow's avatar
alittlelow
I have 17" caddy with a 2" drop and I run 215/55/17 but I guess u can run bigger
dealwithit
should be able to look up a tire size converter, find the overall diameter of the stock tires, then change to 205 or 215 for width and work up from 50 series till you reach the same diameter. if you are planning any drop in the future tho i would deff run something abit smaller, 205/40r17 is pretty common, will keep your rolling resistance down (just based on width), and shouldnt rub at full lock.
