General Discussion \  gm alternator swap
gm alternator swap
General Discussion
views 1326
replies 2
following 2
jdee23   +1y
Hey guys, ive done the gm alternator swap, I did it by flipping it upside down, now having belt alignment problems. I figure I better modify the lower bracket to run the alt right side up so I can insure alignment. If you guys could post some pics if you have done it this way it would be greatly appreciated. Also mines an 86 with the stock carb. I just ran the choke wire to a 12 v source, it does spit and sputter on start up on cold days, is this because of the choke wire? I appreciate any info you guys could give me
mazdatweaker_2   +1y
The stock alternator supplies 7VDC to the choke wire. Running 12V will probably burn it up.
jdee23   +1y
7 volts? Thats strange, so how are guys getting around this?
