I need factory truck pics!!!!!
birdogg27
I have a 1986 mazda b2000 and I am trying to register it as a classic but I need 4 stock factory truck pics one from each side and they have to be straight on not from an angle. Pics of a red standard cab. Mine is lowered and been painted a non factory color so they wont accept my pics. Thanks hope someone can help.
dan woodland's avatar
dan woodland
How does that work? You are registering your truck as a classic but they won't take your truck as the definition of a classic? Isn't that like opening a bag of chips and finding pretzels? Is it that they want to see where you started?
winslow33's avatar
winslow33
I have some pictures of a 100% stock black reg. cab? I'll throw em up later
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
search google photos. done!
birdogg27
Well my truck is in sub par shape because its spray painted khaki and is lowered plus it needs some body work. They want pics of a stock vehicle with factory paint. I have a webber carb and no emissions parts. So if I get classic tags I will be exempt from emissions.
dan woodland
Will you be restricted to miles driven per year? Ohio limits mileage once you go classic or Historical. Be sure that's the way you need to go. Also in Ohio if a car is 25 years old by original model year it's exempt from Emissions testing.
I swapped out for a weber and only have the second cat in place - required for visual inspection. Ohio will give you a temporary waiver if your car fails a test but improves 25% in the failure category so all I had to do was change the timing, get it tested, change it back and get it tested again - our first three tests here are free.
birdogg27
They don't do a tail pipe test here
