Mazda Projects \  Today!!!
Today!!!
Mazda Projects
views 749
replies 3
castaneda8   +1y
Ok..
Today I changed the water pump which was leaking. I changed the crank and cam seal and the oil pan gasket.
The valve cover gasket as well. I also adjusted the lifters and painted the valve cover red. Here is pics of the valve cover and weber.
YEAY!!!!
NO MORE LEAKS!!!
midnightmike   +1y
looks good!
its cleaned up the engine nicely
now you can get rid of all that crap on the passenger inner fender
jester   +1y
Hope ya did a timing belt at the same time, antifreeze turns them to goop after a while. Looks clean under the hood but like Midnightmike said, get rid of all the crap on the fender!!
Cheers
castaneda8   +1y
Well we have to pass deq over here so every 2 years I have to take the weber off. In 5 months Ima see if If I can pass with the weber. If I can than Ima mark the hoses and take that junk out of there. I still need to clean the engine more to. Actually the guy looks lik he had changed the tbelt but was to lazy to change the crank and cam. The tbelt was brand new. Thanks duders
