I hate mazda drive shafts!!
corkin_1@hotmail.com's avatar
impulse's avatar
impulse
I gotta replace mine or something or my support bearing cause mine's fubar'd!!
ughhhhhhh.
drpdmazda
the support bearing is actually pretty easy, there is a big nut inside the joint, spray some wd-40 or something like that on it, then you should be able to break it loose with an open end wrench, after the nut is off tap the drive shaft apart with a mallet or rubber hammer and slide the carrier bearing off, make sure to pay attention to the way it comes off which way its pointing etc. then just do the opposite of taking it out, it should all in all take you less than an hour
impulse's avatar
impulse
Supposedly a shop here where I live can fix them and what not!!! woo hoo
mullet
is he talking about the carrier bearing? They sell replacements.. and i prolly have an extra one or two lying around u can have.
Mike
2fine89's avatar
2fine89
what problem are you running into. ?
kia swap
last post by Brody +1y
51
