Mazda Engine General \  smoking b2200
smoking b2200
views 1348
replies 5
following 6
pure insanity   +1y
ok, i finally got the opportunity to work on my mazda that ive had for like 4 months. it was smoking pretty darn bad so i knew that it likely needed rings or valve seals. i tore it down and put in valve seals. the old ones was in pretty bad shape so i was sure this was a large part of the problem. put it all back together and it seems to be cleared up-untill it gets hot. as soon as it gets wrmed up good it starts to smoke again. never runs bad at all just smokes a light grey/white smoke. anyone else had this and is it a common problem. are there any of the emissions systems that can be causing this? thanks for any help
tunes67   +1y
Well if its happening only when fully warmed up.. and its a constant smoking.. not just puffing smoke when you shift.. then its most likely going to be your oil control rings are worn out.
Tunes67
avtekk   +1y
White smoke is antifreeze, burning oil is has a very distinguished blue tint. Black is too much fuel.
Possibly cracked head?
the twanksta   +1y
My friends car did the same thing..he ended up rebuilding his entire engine b/c just about everything had gone bad...lol. Hopefully your problem isnt as severe!
spoolinx   +1y
what would be causeing it to smoke when you shift?
baggedb22   +1y
White smoke is antifreeze like AVTekk said which could mean u have a blown headgasket or cracked head very common on a Mazda! Blue smoke means ur gonna be needing ring more then likly...
