Fuel Injectors
Fuel Injectors
mxer201
Anyone ever experience a fuel injector that would not work after starting the motor when cold? Then after running for a few seconds it would start working intermittently, after several more seconds work normal. Did you end up replacing the injector or did some concentrated injector cleaner as I'm currently using fix the problem?
mullet
you can run the injector cleaner threw the vacume lines.. however that clears mostly top end.. but works better than the fuel additive stuff.
8
89b2200
Best way is to pull the fuel rail and injectors. Then with a 9V battery, energize the injector while spraying some carburator or throttle body cleaner through the opening. You have to get new injector seals when you put them back in.
Or you can send them out for cleaning and calibration to a calibration shop.
It is also possible your engine computer might be getting a wrong temperature signal from a bad engine temp sensor.
kia swap
last post by Brody +1y
51
