Oil in air cleaner
dandxj@aol.com's avatar
Oil in air cleaner
dandxj's avatar
dandxj
My 90 B2200 with carb has a major oil puddle in the air cleaner. There is so much oil it has saturatd the air filter and runs out of the bottom of the air cleaner. It is not as bad around town but after highway driving oil is all over the engine compartment. The PCV valve is new and has suction. Is all this oil coming from the breather vent?? No smoke on startup or while driving ( that I have noticed). Any ideas??
Thanks
mark's avatar
mark
mine is the same way lol
not sure what to do about it, mine has a foam peice on the air filter assembly inside where the breather goes to...i just clean mine out once in awhile haha
team haymaker's avatar
team haymaker
yeah i get oil in there too, i wouldnt be too concerned
chico's avatar
chico
sounds like we have that in common, I do the same thing Mark does, just clean it once in a while.
mxer201's avatar
mxer201
I had the same problem with an 87 B2600. A new set of pistons rings cured the problem. Air cleaner and inside of housing dry, no more oil.
team haymaker
thats not what id like to hear........my crappy motor was rebuilt about 8 months ago, and its always done that........oh well, if it needs rings then ill just blow it up and put something better in
