Mazda Engine General \  crank
crank
views 835
replies 2
following 2
mazm   +1y
how do you put a key on a crank on a b2000, and what is involved, how long does it take, any help will be appreciated
89b2200   +1y
What are you trying to do? Is the keyway messed up?
Only way to cut a keyway in another section of the crank journal is to send it out to a machine shop together with the timing belt pulley and harmonic balancer. Probably cost you around $50.
Or check out some junkyards with a complete used short block with all the bottom end parts.
Good luck.
mazm   +1y
the key is broke, its on a truck i just bought
