Mazda Engine General \  Mazda motor help
Mazda motor help
views 1277
replies 4
mazdizzle   +1y
Heres what I have I'll give a little background to start off. I pulled my motor the first part of January to start rebuilding it. Everything in the motor is brand new I have around $1,500.00 in it. I set the motor in back in april then bought a house and have had a ton of other stuff to work on so it sat. Anyways yesterday I finally got my battery and fuel cell hooked up and I tried to start it. I ended up having the number 2 and 3 plug wires on backwards. Stupid mistake but things happen. The problem I have now is when I start the truck it runs for a second nice and smooth then kinda backfires through the intake and blows gas out the carb. It won't stay running. I pulled the valve cover and timing belt cover and double checked the timing stuff and it's all ok. My motor has a weber carb on it and no emmissions crap so it's a pretty simple set up. I'm thinking it's a problem with the carb dumping too much gas in the motor but I just need some other opinions. Thanks for any help in advance
mullet   +1y
make sure your dizzy is in straight, and make sure you have that vacume line from the dizzy to the carb.. i'm kinda stumped tho.. wierd.
mazdizzle   +1y
I found the problem it's the weber carb. Just out of curiosity I took it off and checked the float inside and it was way off. I set it to the specs and put it back on and now it runs better but the carb keeps flooding with gas. I had it reved up and gas started pouring out the carb in that little space in front of where the air goes in. I don't know what it's called so that's my best description. When you are standing in front of the truck it's on the front of the carb. I guess I'll take it to a carb shop and have them take a look at it.
nytrdr24   +1y
hey boss,
i just saw you were having a problem with the weber. i saw you said you put a fuel cell in, are you still running a stock fuel pump, or a new electric?
if the carb is flooding, you may have too much psi going into the carb, a weber only needs 3.5-4.0 psi, otherwise you will flood the fuel bowls..
mazdizzle   +1y
Well I took the carb to a local carb shop and for $40.00 they got it all straightened out. I am running a stock fuel pump so I knew the pressure was ok. I'm not sure what ended up being wrong with the carb since the guy that repaired it wasn't there when I picked it up. But when I talked to him on the phone and told him the problem I was having he said it was a very simple fix. I took the truck out for a drive tonight and it runs very strong. This is the first time since the end of december that I have driven it. All I can say is it was nice.
