Still WOnt Freakn Start
sprkndawg
The Battle Continues, My Truck turn over but wont start, I have replaced the fuel filter, spark plug wires and just put a brand new coil on today. I get fuel and I get spark but it wont start it just turns over and over and over....
pont's avatar
pont
there are just 3 things a car needs to run (our trucks anyway) fuel, fire, and them all getting put togather at the right time check your timeing make sure your number 1 piston is at TDC on the power stroke and go from there
mullet
check your dizzy.. make sure its not off 180
Mike
sprkndawg
The thing is , it was running fine, but I let it sit a long time cause I am still working on it. Them bam it wont work.
tunes67
Are you sure you have spark? Easy check.. clip an inductive timing light over #1 plug wire.. have a buddy crank the engine while you pull the trigger on the timing light.. if the timing light fires.. you have spark.
If you have spark.. try using starting fluid down the carb (spray small amounts only).
I ran into a similar problem when I first tried cranking up my engine after it had sat for a while. In my case it turned out to be the fuel pump. The old one was working just enough so I could smell gas.. but wasnt feeding the carb enough to run the truck. Best of luck
Tunes67
kia swap
last post by Brody +1y
51
