Mazda Engine General \  Engine question one and for all
views 2016
replies 10
2blue   +1y
Engine question:
i have a 87 b2600 carbed. now so many people tell me rangers, caravans have this carbed motor but yet every caravan or something isn't the same at all. can some one nfor once claify years to years makes ,models that had this carbed 2.6.?? i know the raider had that motor but we dont have those at out local junkyards.
2blue   +1y
Come on somebody must know? Has anyone looked at there tempature sending unit and remember if there is 1 or 2 prongs on the end? cause mine only has 2 prongs and yet the new one i got from mazda dealership only has one. this is for 2.6 carb
mark   +1y
if im not mistaken, the older carbed 2.6's were mitsu related motors and have no similarities to the newer fuel injected 2.6's (2600i), i dont know if the ranger carbs work or the caravan carbs work.,..but i highly doubt it
2blue   +1y
Ya im trying to get to the bottom of this!!!
rollinslow   +1y
I believe the only other vehicle that had that motor was the mitsu pickup around the same years 87-89. Hope that helps some
2blue   +1y
well this is what i found...
Mitsubishi Model Engine Code Displacement Years Description Bore Stroke
Montero
Pickup G54B RWD 2555cc(155.9") 83-89 12 valve; SOHC 4 91.1mm(3.587") 98mm(3.86")
Starion Turbo
Mazda Model Engine Code Displacement Years Description Bore Stroke
B2600 AM1 2555cc(155.9") 87-88 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Chrysler Model Engine Code Displacement Years Description Bore Stroke
Pickup G52B 1994cc (121.8") 79-82 12 valve; SOHC 4; CARB 84mm(3.307") 89.9mm(3.54")
Challenger
Sapporo/Colt
D50 Pickup
Arrow G54B RWD 2555cc(155.9") 78-80 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Challenger
Sapporo
D50 Pickup G54B RWD 2555cc(155.9") 81-4/84 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Raider
RAM Pickup G54B RWD 2555cc(155.9") 5/84-89 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Aries/Reliant
LeBaron
New Yorker
400/600 G54B RWD 2555cc(155.9") 81-88 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Caravan
Voyager G54B FWD 2555cc(155.9") 84-87 12 valve; SOHC 4; CARB 91.1mm(3.587") 98mm(3.86")
Turbo
Conquest G54B Turbo
2blue   +1y
so does this make any sense to people?
mpenner49   +1y
So does anything interchange?? Can you use any of those motors?
2blue   +1y
all those cars are spose to have the 2.6 in certain years. im trying to get to the bottom of this
mpenner49   +1y
Any luck my friend??
