carb adaptors
carb adaptors
slammedmini469
anyone know if this will fit a mazda?
if so, Holley has a 350 cfm 2 barrel carb....
$260 sure beats $400 for a Weber if it will fit.......
midnightmike's avatar
midnightmike
if anything take the 2 carbs and make your own adapter plate
2fine89's avatar
2fine89
Hmmmm someone needs to buy one and see if this sucker will work.
slammedmini469
im guessing that the jetting would probably be off......but if someone had the time to play around with it, they could figure out exactly what jets a mazda needs and let everyone know.......
slammedmini469
only thing that sucks about those carbs is the manual choke.......but if u dont smoke you could always put the pull knob in the ash tray or something to hide it.....(thats where the switch and button to start my old truck was.....haha)
or just mount it down by the hood popper.....
8
89b2200
It looks like it will not fit the mazda carburator mounting.
I have been working on an adapter plate for a Weber 32/36DG... I got from ebay so I know how it looks.
slammedmini469
post up a pic if possible
costa's avatar
costa
Yah i first hand know that carb adapter WILL NOT FIT i bought the adapter and carb cuz i couldnt find a weber anywhere around and was getting a deal brought my truck to a shop they took the carb out and now its been sitting with no carb for a week cuz i have to get a tool & die guy to make me a custom fit one...so for all you thinkign of buying this carb better look around for the right adapter and if you do find one...PLEASE TELL ME
nytrdr24's avatar
nytrdr24
this isn't an adapter, but a spacer, you might be able to modify it to fit our
intake...don't know tho, i asked this question also in the engine forum holley-weber question, if the bolt pattern is the same on the holley, and weber, you could drill holes to make it adapt to our intake.....
i have had one of these on my old '02 dodge ram quad cab, and now on my current daily an '03 tacoma 4x4, they do help some w/ mid range torque, and gas mileage.
nytrdr24's avatar
nytrdr24
SlammedMini469,
ONE QUICK NOTE ON THE CARB YOU LINKED TO @ SUMMIT,
IT IS A MANUAL CHOKE SO YOU WILL HAVE TO RUN A CABLE
TO YOUR DASH TO OPERATE THE CHOKE..... I THINK YOU WOULD
WANT THE HOLLEY W/ ELECTRIC CHOKE INSTEAD.....
IF THE BOLT PATTERN IS THE SAME ON THE HOLLEY AS THE WEBER,
YOU COULD JUST GO TO REDLINE, OR SOME ONE THAT SELLS THE
WEBER KITS, AND GET THE ADAPTER FROM ONE OF THE KITS TO
BOLT UP THE HOLLEY TO OUR INTAKE.
kia swap
last post by Brody +1y
51
