Mazda Engine General \  Header on an 89 B2200 Automatic
views 2246
replies 13
following 7
scrpnmazda   +1y
What do I have to do to get a header to fit an Automatic Mazda. On Pacesetter it says they are only made for 5 speed Mazdas. I was just wondering what I would have to do to get it to fit my auto. Thanks
flammingjoe   +1y
well on my automatic it was hitting the bell housing but it was just a little, well this is how it went for me, I had the header on not bolted down or anything yet it was almost on when i noticed it was hitting the bell housing it was just the collector part of the header so I i played my luck, when tighting down the bolts on the head its going to want to hit the bellhousing more, so I said well either I am stripping the head bolts or i am getting headers on this, so now I have a pacesetter header on my automatic.....
midnightmike   +1y
im wondering if u take the collector pipe and bring it to an exaust shop and have them put a slight S bend to clear the bell housing and then it should mount right up
low87dawg   +1y
on the pacesetter header why does it have two collectors and what are the pipes in the middle that emmission crap?
pancaked   +1y
those pipes are like a reburner for emmisions they are junk when you put your header on there you throw those out along with a bunch of vacuum lines its a lot cleaner under there when you put your new carb on
low87dawg   +1y
hey do they unbolt on those headers cause on my original manifold i cut them off and welded them up
low87dawg   +1y
the tubes in the middle
nytrdr24   +1y
I JUST GOT MY SET IN, THEY DON'T LOOK LIKE THE ONE IN THE PICTURE, THERE ARE 4 PIPES, ONE FOR EACH CYLINDER, THEY DROP DOWN INTO AN COLLECTOR, THEN THERE IS A SHORT PIECE OF PIPE (@ 1') W/ THE O2 BUNG, THAT ATTACHES TO THE COLLECTOR. SUMMIT HAS A PIC OF THE REGULAR BLACK PIPE, I GOT THE ARMOR COAT TO KEEP THE UNDER HOOD TEMPS DOWN.
midnightmike   +1y
umm that header is for an inline 6cyl.
low87dawg   +1y
yea it looked like a straight six but it said 2.0l or 2.2l but it looked like those exaust receculator things
