Mazda Engine General \  swapped 2600i into a b2200
views 837
replies 2
following 2
brokemazada   +1y
ok i swapped a 91 2600i into a 92 b2200 body, i swapped most of the engine harness into it, the only thing is i dont have the wires for the ignitor, coil so i not getting any fire. i got a wiring diagram and got it wired up the best i can, i got the signal wire from the computer hooked to the ignitor, the coil is wired up, the signal wired from the ignitor is has 12volts going through it, is it suppose to have 12 volts or what? any help will be very helpful thanks
drtyhatch   +1y
hey i know this isn't any help to you but maybe you can help me, did that motor and transmission just bolt in, or did you have to do motormount work?
brokemazada   +1y
yes i had to cut the 2.2 motormounts out and weld the 2.6 motore mounts in its easy to do if u have the tools and the know how took a half a day with a sawzall and a welder
