HELP, Clutch Pedal Sticks, and truck dies
sprkndawg
I have a 89 mazda thats my daily driver, I just bought it a couple days ago, i has sat since setember and I bought off a guy who never drove it anymore, anyways, randomly sometime a lot when I am driving I push in the clutch pedal and I dosnt come back up and I cant shift and it starts to die and dies if I dont give it gas. so at stop signs I have to let it die sometime, but it starts back up/
8
88lx
Sticking release bearing???
8
89b2200
Could be one or combination of three.
1. Master cylinder leakage past seals.
2. Fexible fluid hose leakage located in firewall. Check for fluid under the dash above the clutch pedal.
3. Slave cylinder leakage. Pull rubber boot off the slave and see if fluid leaks out.
As far as idle dropping, that is because the clutch is not releasing while you are still in gear and coasting to a stop.
Do you shift while stopped? Then start the truck back up in neutral? If yes, it is just the clutch not releasing. Check the above 3 causes.
87mazdamini's avatar
87mazdamini
Mine was doing the same thing and it was my slave cylinder. 18 $ from carquest
sprkndawg
Thanks for all the help, I think I got it fixed, I replaced the slave cylinder but that didnt help so I replaced the clutch master cylinder and now it seems like everthing is now working properly. Its been a busy day.
vidraggin's avatar
vidraggin
yea I just replaced my slave and master and bled and bled and bled and now have a clutch.
sprkndawg
lots of bleeding, yeah, everything seems to be working now.
kia swap
last post by Brody +1y
51
