b2200 slow nasty rough idle
czarnock@adelphia.net's avatar
nvious kreationz's avatar
nvious kreationz
Fellas I need help this is my first Maz its an 87 2200 5pd se-5 it starts only when gas pedal is floored as soon as you let of it quits the idle is real slow and rough i changed the fuel filter added fresh gas and even some dry gas i took off the air cleaner and it spurts out little drops off gas from the carb and if you add gas to the carb it i guess floods out. Any ideas or suggestions?
hybrid
there are plenty of threads on this topic,most likely your choke is sticking.i had the same problem.
8
88lx
Try cleaning it inside and out with a good carb and choke cleaner.
thetornado's avatar
thetornado
sounds like your carb. def get that baby cleaned out. try spraying some starting fluid in the carb when ur cranking it. plus make sure all those little vacuum lines are connected.
nvious kreationz
Well today i replaced plugs, cap, rotor, and wires it fire right up ran like hell than went back to same rough idle when floored. I am going to try and bottle feed the carb tomorrow and see if any luck any more ideas will be greatly used
nvious kreationz
Question where is the choke located I have been searching other threads and guys have the same problem and refer to the choke?
nytrdr24's avatar
nytrdr24
our trucks have an electric choke, the flap in the bore of the carb is the actual choke, and if it is closed and hanging it would cause your problem, or there could be a vacum line off. best bet is hose it down with carb cleaner, let it set, then give it a try again.
speedster93b's avatar
speedster93b
Nvious Kreationz Posted: Sat Dec 31, 2005 2:01 am Post subject:
I read this post and interpreted it as your truck does the rough idle thing when your accelerating. is that right? or all the time? if its when it's accelerating (or should be accelerating when floored) sounds like it could be your accelerator pump in the carb. could be sticky/stuck
FN
f n lo
i had some what of the same problem, i ended up taking the nox pipes running into the intake housing shoving bolts down them to block them, the truck ran like a dream, it worked awsome, it might be your problem to, to much exhaust going back into the engine, or the clutch liek all these boys are saying,... i replaced my carb., with another rebuilt one, and it still ran like crap only until i did this.....just an idea.....
nvious kreationz
thanks guys i will do some more tinkering./ Also i was thinking of running a different carb like a weber if i do that will that get rid of all the lines and be easier to tune. what did the weber carbs come on from the factory?
kia swap
last post by Brody +1y
51
