thinking about swapping engine
b2wd
a dude has a 90-91 b2600 4WD that i can get for a sixpack and some lollipops, will my -91 b2000 2WD engine fit in that truck or should i just forget about it ?
/Mike
pont's avatar
pont
the trannys are differnt so i dont hink you can use the 4x4 stuff but it should fit if you carry over everything motor, tranny, motor mounts, drive shaft (if its the same body stlye) not sure on the front but you will have to probly take the front suspenson off and trade as well
b2wd
I was afraid or that answer, see i was after the 4wd stuff but wanted to use my engine
FN
f n lo
hey, id say grab the truck, for what you have to pay it woul dbe silly not to, then swap all the body parts over to your truck, if you dont wanna go thru all that work.... i noe some that is looking for 4x4 stuff
mazdawgydawg's avatar
mazdawgydawg
i say u get the truck and then send it to me HAHA jk but get it no matter what if u cant get ur engine working in there keep the metal
b2wd
Send it to ya...jup if you pay for the stamps
seriussleee is an old mazda truck expensive in the U.S (or Canada) or are they just hard to get by ?
A different question is, what are those pipes that runs from the air cleaner and then backwards. I have this cool airfilter that i would like to fit but dont know if it is possible.
You can tell i´m a real rookie by my questions cant you
nytrdr24's avatar
nytrdr24
just depends on what shape they are in excellent cond @ $3,000 us
the pipes are part of the exhaust gas recir. sys. you can remove them to
use your air cleaner, but they are attached to the exhaust manifold. you will have to find some way to cap them off, or get a header, this would allow for a much cleaner adaptation.
kia swap
last post by Brody +1y
51
