Are mazda's known to have a loud valve train in them cause mine makes a ticking noise it has 136000 miles its a 91 b2200 se5. I had another 91 b2200 and it had a 160000 miles on it and it didn't make the ticking sound my se5 makes.
mullet
could be the valves or the crankshaft.. and yes it is common. Typically if you run a gas improvement additive or higher octane gas it will make it quieter or temporarly eliminate the sound.. but sometimes it dosen't and that gets expencive.
Mike
pont
might be your lifters sticking does it sound like manual lifters that need to be tweaked if so then try runing some kind of cleaner not sure what kind
nytrdr24
DEFF. SOUNDS LIKE YOUR LIFTERS. I THNK THE PRE 89'S HAD THE MANUAL LIFTERS, 90-93 HAD THE HYDRAULIC
pancaked
yeah its the famous mazda lifter tap id say 80 percent get it
mazdawgrollin
89 b2200 had hydraulic lifters too.
g&k_customz
my lifter have been making that noise since like 124,000m its got over 180 on it know
shapinoweno
My 86 b2000 does the same thing, it is pretty loud. Also it smells like I am burning oil I'm not shure why it smells this bad, but it drives great, it only has 86k orig miles. Not shure if I should be worried about the smell its making though
