Mazda Engine General \  How to?
How to?
views 809
replies 3
nonamedsomebody   +1y
How do you run dual alternators on a 91 mazda b2200 ext cab
what I should of posted is how do you run the wiring for a dual alt setup?
Do you splice into the current wiring or run new?
Post was last edited on Jan 31, 2006 05:01. This post has been edited 1 times.
slammed83mazda   +1y
make ur own bracket i was thinking of doing it but im just gonna convert my compressors for my air ride to a engine driven because the compressors are pulling 40 amps together and it hurts my battery.
bryandamage   +1y
i'd probably go for a single higher output alternator. the wiring would be so much simpler. what's the benefit of two?
nytrdr24   +1y
I'D RUN ONE BIGGER ONE ALSO, EITHER GET THE STOCK ONE REWOUND, OR PUT A HI OUTPUT CHEVY ON, ADDING ANOTHER ALT. WILL ROB MORE POWER FROM AN ENGINE THAT LACKS IT ANYWAY. THE LESS ACCESSORIES, AND ROTATING WEIGHT THE LESS YOU WILL ROB POWER FROM THE MOTOR.
