How much psi runs in the gas lines?
juggalo_joker2003@yahoo.com's avatar
slammed83mazda's avatar
slammed83mazda
Im about to re-locate my gas tank and i need to know if mazdas run alot of psi in the fuel lines, reason i ask is cause i know s-10s do and they require you to buy a high psi line to run it safely, i am just curious to know if mazdas are the same or would it be fine just to go down to auto zone and get some regular fuel lines, thanks guys.
tunes67
Depends on what truck you have.. if you have one of the fuel injected trucks.. the fuel in those systems is under a lot more PSI than your naturally asperated trucks. I know that in my truck, being that its got the carb & mechanical fuel pump.. that the fuel is only under any kind of real pressure (if much at all) between the fuel pump and the carb. The fuel is being "sucked" from the tank upto the fuel pump.. then being pressurized as its delivered to the carb. Now the fuel injected trucks.. might have an electric fuel pump in their tanks.. (Most fuel injected applications are this way.. but not all and I dont have first hand knowledge of the B2600i's system).. and if they do have the electric fuel pump in the tank.. then the entire fuel line from tank to engine would need to be able to sustain higher pressures over extended periods of time. Sorry I dont have any specific numbers to give you on this.. just a small bit of logic. Cheers
Tunes67
maz
they make fuel injection hose it costs more than reg feul hose it should work
slammed83mazda
ahhh sorry, i should have listed what i was running tunes my apology.
I got a 83 mazda b-2000 2.0 liter and it is not fuel injected, its on a carb, so i take it regular gas line would work am i correct?
mark
yes, regular gas lines will work
slammed83mazda
thanks bro
nytrdr24's avatar
nytrdr24
3.5-5 psi carb'd or 35-45 psi f.i it all depends on the pump & if
you have a psi regulator. when i start puttin my fuel system in,
i am replacing the factory hard line, and putting in 3/8" stainless
hard line, and using flex hose for connections to the carb, regulator,
filters, pump, & fuel cell.
slammed83mazda
alrady got the problem fixed
nytrdr24's avatar
nytrdr24
kool!
slammed83mazda
lol NTYR, are we a post whore lol go look at the engine section i see at least 7 post right in a row from you. hehe
kia swap
last post by Brody +1y
51
