Mazda Engine General \  A wire to disable start-up
views 976
replies 8
following 7
cid (dale)   +1y
Ok, i wanted to know what wires i could tap into to disable the truck from starting. It's kinda like a cheap alarm. I'm going to put a switch in under my dash or somewhere and want to know what i could tap into to make it work. Has anyone done something like this before?
Thanks,
Dale
mazdizzle   +1y
If you wanted to do this you could cut the starter wire and run it to a switch. The color black with a yellow line and it's located on the steering column with abunch of other big wires 12 gauge or so.
nytrdr24   +1y
YOU NEED TO BREAK THE SWITCHED SIDE OF THE IGNITION, THIS IS THE WAY YOU HOOK UP ONE OF THE "START BUTTONS", BUT SINCE YOUR DOING IT AS A START DISABLE, JUST PUT THE SWITCH UP UNDER THE DASH, IT SHOULD BE RATED FOR MOMENTARY CONTACT THO, CAUSE IF YOU HAVE A CONSTANT ON, IT WILL BURN UP YOUR STARTER. NOT SURE
OF THE COLOR OF THE WIRE....SORRY!
johnh2os   +1y
Do you Smoke? If not you can use your cig. lighter as a kill switch.....with it out in the normal position you cant start the truck, when you push it in you can start it like normal. Just a thought.
John
Post was last edited on Feb 05, 2006 01:02. This post has been edited 1 times.
2fine89   +1y
LMAO I was thinking the exact same thing ..
cid (dale)   +1y
That's a good idea, but unfortunatley i smoke . I have a spot to put i pull switch so no worries about that.
I was thinking about the starter wire but didn't know where it was located. I'll be doing some new wiring next weekend so i think taking it off the starter would work well .
Thanks guys,
Dale
midnightmike   +1y
well if the truck is a 5 speed, i wouldnt to the starter wire cuz all someone needs to do is push it down the street and pop the clutch, i would use the igniton wire, which will not turn on the coil and the fuel pump,, or u can just pull the fuel pump fuse, in the dash its real easy that way
f n lo   +1y
what color is the ingnition wire??i noe its right on the steering coloumn but whitch one is it?? i can use a test light becasue nothing is connected right now....
mazdizzle   +1y
Ignition wire is black with a white line.
