Mazda Engine General \  how to adjust idle? and..
views 1079
replies 10
robbie   +1y
How do you adjust the idle on a carbed 2.2L? and I have a plug that isnt hooked up. It runs out of the back of the carborator and its a yellow wire with a blue stripe down it. It runs towards the front of the truck but I can't find anywhere to plug it into anyone know what it is or where it goes?
lukeinva   +1y
there is an idle screw on the passenger side of the truck turn left to lower idle, turn right to raise idle. The wire may be for your choke.
robbie   +1y
if it is the choke where does it plug in at?
lukeinva   +1y
on the right of the carb you will see a metal electical connector it goes there. If there is already something hooked there then its not it. Is it a wire?? is there any kind of adapter or plug on the end of the wire??
nytrdr24   +1y
THE CHOKE WIRE RUNS FROM THE CHOKE ON THE CARB TO THE ALTERNATOR.....
lukeinva   +1y
yeah make sure you check both ends of the wire!:)
robbie   +1y
Its a yellow wire with a blue line down it. It will plug onto a blade type connector.
nytrdr24   +1y
WHICH END ISN'T HOOKED UP, THE ONE ON THE CARB, OR THE OTHER END. THE CARB END GOES TO THE CHOKE HEATER, IT IS ROUND W/ ONE OF THE BLADE TYPE OF CONNECTORS ON IT, THE OTHER END GOES TO THE BACK SIDE OF THE ALTERNATOR, THERE IS SOME PLUGINS ON THE BACK OF IT.
robbie   +1y
it was the end not connected to the carb I'll go check the alternator now thanks.
robbie   +1y
there is already a plug plugged into the back of the alternator and the wire wouldn't reach down there to plug into it so I dont think it goes there. Its dark now I'll try and get a pic tomorrow unless anyone has any other ideas?
