1991 Mazda B2200 (carb) Im new here...
onenamylyn2001
I have a 91 b2200, and i was wondering what some basics mods would be to up the power a little and any other beginners mods you would suggest.
Thanks a lot
onenamylyn2001
My truck smokes on start up and stops shortly after when the truck warms up. Any suggestions? inexpensive fix or worth the investment?
thetornado's avatar
thetornado
white smoke? and how bad?
mine smoked a lot before i rebuilt my engine. in most cases you need to replace your valve seals. at least i know mine were shot. happens a lot of the time.
onenamylyn2001
sometimes its a thick white smoke, how bad depends on the day and maybe the weather. Sometimes its thin grayish smoke and sometimes it thick white smoke and it can be pretty bad. thanks for the reply. What is your take on a weber carb added to my truck will it up the performance?
onenamylyn2001
its all stock no performance mods ..... yet. help.
nytrdr24's avatar
nytrdr24
deffinately replace the valve seals, that will stop the smoking. if you aren't planning on getting a cam, i'd just get the 32/36 weber, it will get better gas mileage than the 38, then get a pacesetter header w/ new exhaust
out the back, and look into an upgraded ignition system from accel or crane cams......loose the stock clutch fan for an electric w/ an adjustable thermostat, put a 2-row radiatior out of an automatic if yours is a 5-speed.
you can also put a fidanza 9.5 lb flywheel and a perfomance clutch in, this will let the engine wind up a little faster.... other than that, if you want more, you'll have to tear into the engine and rebuild it, or put a turbo on it from a ford probe/ mazda 626
oh, i forgot, welcome to the scene!
onenamylyn2001
mine is a five speed. How much horsepower would this carb add to a stock motor?
nytrdr24's avatar
nytrdr24
the 32/36 carb prob @ 5-10 hp on a stock motor,
add another 10 hp for installing a header....
FN
f n lo
i gotta turbo enigne for eya ;) lol, im throwing a weber on mytruck as well, header, now who makes a performance cam for our trucks??
nytrdr24's avatar
nytrdr24
kia swap
last post by Brody +1y
51
