Mazda Engine General \  carb problems
carb problems
views 668
replies 2
following 2
cabizzle16   +1y
i have a 1991 Mazda B2200 with a stock carb and my carbeurator will idle too high then sometimes it wont idle at all and i have to pump the pedal to keep it going. u guys have any suggestions on what I should do? thanks for all your help.
nytrdr24   +1y
SOUNDS LIKE A TYPICAL MAZDA CARB, TRY HOSING IT DOWN W/ CARB CLEANER, & A LITTLE SCRUBBINS W/ A TOOTH BRUSH OR PIPE CLEANER.
IF THAT DON'T WORK, YOU MAY NEED TO ADJUST THE IDLE CIRCUIT SCREW. ALSO MAKE SURE YOUR FUEL FILTER IS CLEAN, & REPLACE IT IF NECESSARY.
GOOD LUCK!
cabizzle16   +1y
i just bought a new fuel filter but i will clean it good and see what happens. thanks.
