Mazda Engine General \  B2200 Idle Up Solenoid
views 1867
replies 4
following 2
rockinw   +1y
When I turn on my a/c the idle up solenoid just pulsates the rpm. If I disconnect the plug to the idle up solenoid it stops. Any idea what may be wrong here?
89b2200   +1y
Check the vacuum lines and the actuator diaphragm for leak or torn diaphragm.
If they are good, blow some air into the solenoid ports to clear the passage with the A/C on and plug connected.
If it still pulsates, check the voltage at the plug for pulsation. It should be a steady 12V.
rockinw   +1y
Thanxs for the direction, I will try those steps..
rockinw   +1y
I put a vac gauge/pump on the diaphragm and it will not hold a vacuum. lines are good so I think the actuator diaphragm must be bad.
89b2200   +1y
Yes, diaphragm is bad. It should hold vacuum.
