get the 32/36 or the 38
low87dawg
hey i was wondering if i should get the 32/36 or the 38 weber carb????????????????????????????
pancaked
38 man just like drugs brother bigger is better
nytrdr24's avatar
nytrdr24
IF YOU AREN'T GOING TO DO A WHOLE LOT TO THE MOTOR, THE 32/36 IS BETTER ESP FOR FUEL ECONOMY, BUT IF YOU ARE GOING TO DO A HEADER/CAM OR ANY OTHER INTERNAL MODS TO THE ENGINE THE 38 WOULD BE THE BEST BET.
roach25681
The 38 doesnt get any less gas mileage than the factory carb. I run a 38 with a header and it runs fine. When its running anyways...
FN
f n lo
do they have manuel or no choke at all??
russ d's avatar
russ d
yes, with a manual choke its called a 32/36/dgv or 38dgs, if you want no choke at all, you can just pull the choke butterflies.
d= downdraught
g= is the side the throttle linkage is on, if it were dfev the carb would be a mirror image with the linkage on the other side. This is what the holley 5200 was based on, the dfev carb, and thats why people have to make throttle linkage to work with them.
e= electric choke. an "a" here is for "agua" or water choke, no letter in this position indicates a manual choke.
v= variable or some italian word for variable that starts with a v, its a progressive carb that opens one barrel first, then the next. an "s" here means syncronous, both barrels open at the same time. this is where the numbers come in, 32/26 means 32mm primary. 36 mm secondary. the 38dges means two syncronous 38mm barrels.
A 32/36 is easier to tune on a stock motor. Syncronous carbs have great off idle response, but aren't really needed if all you have is a header. You will be detuning the 38dges to work properly. And you may not lose any mileage over the stock carb with the 38dges, but you will gain some with a dgev. Something to consider.
low87dawg
well all i got is a header
and i can unplug that whole wiring harness on the passenger side right
i got rid of my wiper motor so i dont need any of those wires do i but isnt one of them for the horn???
russ d's avatar
russ d
no, without the carb and without wipers you can get rid of that entire harness. Just make sure you unplug everything first, some of the wires go to the fusebox by the battery.
low87dawg
i got rid of the fuse box
saggio's avatar
saggio
Will you pass emissions with a weber carb and header?
Anyone have a DIY Weber install? (What vaccum lines do you need to save, and which ones do you toss)
kia swap
last post by Brody +1y
51
