Stock gas tank
Stock gas tank
roach25681
Is it possible to drop the stock gas tank without taking the bed off? Last time I bagged my truck I had the bed off when I removed it so I cant remember right off hand. Im thinking there are 3-5 bolts on each end and thats it? Or is there more?
nytrdr24's avatar
nytrdr24
I'M PRETTY SURE YOU CAN, IT'S JUST A LOT EASIER W/ THE BED OFF...
baggedb22
Yeap you can drop it with the bed on, Just a couple bolts on each end...
roach25681
I figured you could. I just came in for the night and didnt feel like going back downstairs to check. Im lazy, its Friday night. Its been a while since I dropped one and the bed was off.
blare
umm i cant imagine trying too. There are two bolts in the front where that crossmember behind the cab is and two on the back. All 4 are 12mm hex heads. I think you might have to pull the bed off because when i did mine the two bolts in the front of the tank had one facing down and one facing up (they are apart of the tank). I dont think you can get to one of the nuts without talking the bed off.
maz
yep you can you can reah your hand around but sounds like someone has been into yours before you??
roach25681
Oh well, if its to much of a pain to get to then I'll just cut the damn brackets off.
blare
Dont forget your next to a gastank
roach25681
Sawzall, less sparks....i tend to get ballzy/STUPID when it comes to cutting near shit I shouldnt be.
kia swap
last post by Brody 12 mo
51
