bigger gas tank?
bigger gas tank?
mjohnhs
i have a 89 b-2200 5-speed.
it have the stock gas tank. my fuel tank gauge went out.
so i thought if i'm going to change my gauge, why not get a bigger tank?
but how big of a fuel tank can i get?
anybody know any in-put
low87dawg
why get a bigger tank?
low87dawg
i got a 17 gallon fuel cell in mine
nytrdr24's avatar
nytrdr24
ARE YOU SURE IT IS THE GUAGE & NOT THE SENDING UNIT IN THE TANK?
AS FAR AS SIZES OF FUEL CELLS OR GAS TANKS, LOOK ON SUMMIT RACING, OR JEGS AT THE FUEL CELLS TO GET SOME KINDA IDEA ON THAT.
mark
if you're not planning on doing any suspension work, you could get a longbed gastank if you have a std cab, excab gastank will work too, they are bigger by gallon or so
mjohnhs
thank you all for all the input, and NYTRDR24 you are right it is the SENDING UNIT.
think i'm going with a 17 fuel cell
nytrdr24's avatar
nytrdr24
IF YOU ARE GOING TO RUN A CELL, THEN YOU NEED TO GET ONE WITH A BUILT IN SENDING UNIT, THE JAZ 16 GAL PRO-STREET THAT I'M LOOKING AT HAS A UNIVERSAL SENING UNIT SO THER SHOULDN'T BE ANY PROB WITH
IT & THE STOCK FUEL GUAGE...
russ d's avatar
russ d
if you use the "universal sender" it is usually a GM style which reads 0-100 (o empty, 100 full). The mazda reads ~90-0, so your gauge will work, albeit backwards. You'll amaze your friends by actually showing MORE gas when you arrive than when you left.
If you have the choice, get the older ford sender which reads ~80-10. Your gauge will work in the proper direction and indicate empty before you are actualy empty...
lukeinva
Russ what if you hook that up to an after market gauge like autometer. Would it still read backwards??
nytrdr24's avatar
nytrdr24
heres a link to the page of the jaz cells, the one with the sender i was going to get is a 16 gal 240-33 ohm.
russ d,
i know you've heard it a million times...you da man! i had asked around, not here tho...to find out what ohm range was needed to get the guage to work properly, that is why i was going to get the universal, but now that you
have said an 80-10 will work, they offer some 70-10 ones, which one would you go with?
kia swap
last post by Brody 12 mo
51
