head rebuild
head rebuild
mazdabon2nd
is there a place where i can get a kit to jus rebuild my head of my truck like valves and springs ect.?plz help
mazdizzle
I had a machine shop by me rebuild mine last year. I think it was around 275.00 and they did a valve job replaced a couple valve guides and machined the surface. Call around and see what machine shops around you would charge.
mark
hey bro you can't just slap on new valves, etc. you have to get the head machined to match up the new valves so they will seat correctly.
just check with a local machine shop for prices, that'd be your best bet
8
88lx
You can buy a remanufactured one for around 300. Try Cylinder Heads International. or shop EBay.
drpdmazda
just make sure you replace the head bolts, i know a lot of people say you dont have to, but i just spent about $200 to have my head rebuilt last summer, and didnt have new head bolts put in, the head warped from improper torque so now im back to square one
baggedb22
Get some valve grinding compound and do it yourself, its not hard to rebuild at long at the heads not cracked/warped. With the valve grinding compound you put some on the valve put the valve in the valve seat and put a drill on the other end just go at a moderate pace, will the part where the valves seats is all shinny agian, As for valve seals and everything else its not to big of a deal, You should be able to figure all that out on your own. Good luck bro!
mazdabon2nd
ight cool im gonna try that ill hit u back if i need ne more help with this subject thanks
luv2sprk's avatar
luv2sprk
dang, my machine shop took my head apart and ground the exhaust valves and decked the bottom for 30 bucks, he even put it back together for me, it didnt need new seals or anything, but $300 sounds high?
nytrdr24's avatar
nytrdr24
very tru, or you could even get some studs instead of bolts for more reliable / even torque pressure on the head.
kia swap
last post by Brody 12 mo
51
