Will this engine possibly fit?
dn9979
Im in the middle of parting a 1993 mercury capri
has the maz/ford 1.6l turbo motor in it.Its complete and it runs.
is it possible?
shares alot of parts with the mazda 323
baggedb22
anythings possible man!
slammedmini469
only problem i see is that it is a FWD engine.....but so is the probe engine and it is a common swap, so who knows......
my suggestion would be to find a festiva to bolt it into
dn9979
well since its pretty much free i thought its worth a shot.
just have to see if my mech is interested in doing the swap
midnightmike's avatar
midnightmike
i thnik the trannys out of the miatas will bolt up to that motor, they do share alot of parts, u can make it fit probably making a custom bell housing
slammedmini469
^^ i beleive mike is right. i am pretty sure the capri engine and the miata engine are the same with a few variations......dont quote me though
slammedmini469
ok, after doing some searching on , i have found out that yes, 1.6 miata engines and 1.6 capri engines are the same block.....
that said, you would need to
-notch the firewall for the distributor
-buy a miata trans, clutch, and flywheel
-make new engine and trans mounts
-build an exhaust system
-wire it up
that should be it....
Post was last edited on Apr 15, 2006 04:57. Edited 1 time.
slammedmini469
another option would be to pick up a 1.6 miata engine/transmission and swap the turbo system onto it.....
kia swap
last post by Brody +1y
51
