what is this clickey relay?
sketchystreet
I had a horrible clicking noise for about a week or so. I finally found it to be a relay under the hood. Its a round metal relay right behind or 2 behind the battery. I took it out because i couldnt take the noise anymore. Do you guys have any idea what the relay is for?
W
webpage
i know that the horn relay is right behind the battery mounted upside down on the fender wall......does your horn work??
sketchystreet
Wow. I never put that togther. After the accident i went to hook up the horn and it was a constant power. Ill have to check the wire again to see if its hot. If there isnt any power then that is what it is. good lookin, thanks
sketchystreet
nope no go on that one. I still have a constant power to my horn even though that relay isnt connected. i tested all the plugs on the wire end of the relay and no power to any of them even when the horn is pressed. no idea.
kia swap
last post by Brody +1y
51
