2.2 with a 2.0 trany
olskoolshroom@yahoo.com's avatar
greenguy83's avatar
greenguy83
So my engine is about done. I have a 86 2.0. Would a 2.2 engine fit my transmition like an easy bolt up. Thanks
madmazda
It may, but then again it may not...
drpdmazda
i dont see why not, from what i understand the only difference between the 2.0 and the 2.2 is basically the heads, so if that is true then the trannys should be the same
madmazda
different gear ratios? no? different size engines, not by much, but still slightly different...
nytrdr24's avatar
nytrdr24
it would be a direct bolt up, you will have to change out the engine mounts tho. as for difference, the heads are the same, the block is just taller to compensate for the added length in stroke.
mazm's avatar
mazm
i put a 2.2 in my truck with my stock 2.0 transmission
pont's avatar
pont
i had a 89 B2200 tranny in my 86 B2000 (with the 2.0) i think the tranny supports are differnt not sure (the 2 supports that bolt to the block and the lower 2 holes on the tranny)
kia swap
last post by Brody +1y
51
