91 B2200 carb in 87 B2000 ???
lalunette
Hi folks!
Anyone know if a 91 B2200 carb will work in an 87 B2000 ???
The base looks like it will fit.
Cheers and Thx !!!!
nytrdr24's avatar
nytrdr24
IT SHOULD BOLT RIGHT UP TO THE INTAKE, BUT AS FOR THE VAC LINES I'D SAY THERE IS SOME DIFFERENCE, NOT SURE THO
lalunette
I have some pics so I'll try to match up the vac lines and let you know...
It certainly looks like it will bolt right up... but my question was more of the "internal guts type" variety, i.e. will a carb meant to run a B2200 engine work okay on a B2000 engine?
Cheers !!
nytrdr24's avatar
nytrdr24
i believe that the carb for the b2200 is just a little bigger + has more vac stuff hooked to it than the b2000 carbs
bmxmarine
it will work that is kinda what my boddy has done but you will have alot of vacume "problems", not really problems but you need to match up what you need between the 2 trucks to make it work.
kia swap
last post by Brody +1y
51
