stock carb question...
bmxmarine
ok i just bought this 86 b2000 from my brother and he recently had a guy replace the carb and the funked up all the vacume lines and now i am lost i tried the whole "redoing the vacume lines" thing but that isn't working out...it has an 88 or 89 b2200 motor in it...ahhh i just need to get it working. well my questions are as follows:
1. can i disconect all the vacume lines and cap them off?
2. where on the carb does the vacume advance go?
3. if i can run it with out the vacume lined is it ok to do for a little bit?
4. the webber carb looks like it will solve alot of my problems but what will i need to keep?
brandon005
1. No unless you want your truck to run so rich you plug the cats and only get about 12mpg
2. hard to explain
3. not really I wouldn't do it for more than 50 miles or so
4. The weber will eliminate all of the vaccum lines except the vaccum advance line it is also the best upgrade I have done to my truck it makes it run soooooo smooth
kia swap
last post by Brody +1y
51
