Mazda Engine General \  weber 38 Qs
weber 38 Qs
views 685
replies 5
following 2
rob   +1y
so is it possible to get a weber 38 with a manual choke? Im going to be buying one soon but i was just curios i would really like a manual choke.
nytrdr24   +1y
there is not a 38 with a manual choke, only electric & water....sorry!
you can get a 32/36, or i think an interco/weber 34 with a manual choke
rob   +1y
will i still get ok power out of either of those carbs and how much is the interco 34 cost wise
nytrdr24   +1y
DEPENDS ON HOW MUCH POWER YOU WANT, CHECK OUT THEY HAVE GOOD INFO ON THE WEBERS, AND
GOOD PRICES ON ALL THE KITS. ONE Q THO, WHY DO YOU WANT A
MANUAL CHOKE INSTEAD OF AN ELECTRIC ONE?
rob   +1y
well ive had some problems with my choke sticking on so i thought if i was to get a manual choke i would never have to worry about that again. I would really like the 38 so if you think i wouldent have any problems with it stickin just let me know.. thanks
nytrdr24   +1y
THE PROB WITH THE CHOKE STICKING CAN BE A MAINTAINCE ISSUE, IF YOU DON'T KEEP A CLEAN AIR FILTER MORE DIRT WILL ENTER THE SYSTEM
AND CAN CAUSE IT TO STICK, SO I TRY TO REPLACE THE FILTER OR CLEAN (IN THE CASE OF A K&N) IT EVERY 10,000 MI DEPENDING ON HOW DUSTY YOUR SURROUNDINGS ARE, AND ALSO SHOOT A LITTLE CARB CLEANER ON IF IT'S LOOKING DIRTY FOR GOOD MEASURE. I DON'T SEE WHERE YOU WOULD HAVE A PROB IF YOU DID THESE THING WITH THE 38, THEY ARE MUCH MORE RELIABLE THAN THE STOCK ONES THAT CAME ON THE MAZDA'S.
