Mazda Engine General \  Chevy 305 and a turbo 350 swap
views 803
replies 2
following 2
madmazda   +1y
Hey guys, i'm deciding whether i want to do as the title says, i can get a 305 and turbo 350 tranny for cheap...i was told that that i could change the gears in my rear end and have the rear end hold up to the 305, is that possible? I was also told that there's a adapter plate to run our tranny (mazda) to a chevy motor, but how would that work? gear ratios, etc...also turbo 350 tranny,e tc....i need some information here gear heads!! Thanks!!
limequat   +1y
Hello.
The stock Mazda gears will have no problem with the 305. If you want a different ratio, there are a variety of gears that will interchange.
I don't know about any transmission adapters. Probably be easiest to use a chevy trans and then just get a driveshaft made. Don't bother with a 3 speed, get a 4 speed if you can swing it. Otherwise, you'll be running ~4000 rpm on the freeway.
madmazda   +1y
hmm... anyone know where i can get 221 gears for my rear end??...
