2600I run with cam out a tooth?
bulldog14692
I put my engine back together, apparently I didn't get it back together correctly. I had to move the plug wires one over to get it close to hitting.
The engine runs good while parked, revs good, idles good, doesn't miss or anything. The road test was way dissapointing, loss of power big time. I had to near wind out 1st so second gear could take over.
The only thing I might have done wrong is put the cam pulley in with it being out a tooth. This makes snce to me because it still combusts but maybe it has some blow-by since the valves are not seated all the way.
Any other suggestions, before I take the valve cover off? or info needed?
Only had the head worked, never went into the bottom of the engine.
originalmazdawg
pull it!
kia swap
last post by Brody 12 mo
51
