trans questions ???
trans questions ???
carolinasled
1,2,3,4,5 or cool but if i stick it in reverse and take pressure off of it with my hand it jumps out everytime. Is this common or not? or what could it be???
also my fuel gauge only works when it wants to, what can i go about doing to fix this problem also????
nytrdr24's avatar
nytrdr24
check the wiring connection on the sending unit @ the tank sounds like you have a bad connection or short in the wiring...at worst the sending unit itself is going bad.
pont's avatar
pont
It could the pilot berring in the flywheel. which is what i would try frist since it does not cost much and is pretty much clutch change (change it to if you have not). if that does not fix your problem then its most likly your input shaft berring on the tranny in which case you will need to have the berrings replaced.
kia swap
last post by Brody +1y
51
