carb\distro ?
carb\distro ?
bmxmarine
where does the advance go to on the carb? the motor is an 88 b2200
8
89b2200
On a stock carb, from intake manifold vacuum tap to the 12V solenoid valve beside the thermostat housing to the dizzy vacuum advance.
bmxmarine
well after alot of work i found that the port right above the heater plate wire only starts to have vacumm after the rpm increases so i just hooked that up to the distro and bam it works awsome....before i was just running it off of the manafold so wea this is alot better
kia swap
last post by Brody +1y
51
