Mazda Engine General \  19932600i over heating
views 535
replies 4
following 5
mazdawg69   +1y
hey guys i just bought another mazda when i bought it it was having a overheating problem so i pulled the thermastate out and the thing kept on over heating so i took it to a freind and he said the headgasket was gone so i took the head in and had it machined and the headgasket changed i got it back and it was running mint until today i took it for a long drive and the tempature gage started to go really high above average today was a really hot day but i think there is something still wrong with it does anyone have any advise thanks.
baggedb22   +1y
Did u have the head checked for cracks when it was out? The 2.6's were known for cracked heads..
madmazda   +1y
Check your Rad too...on the inside, it maybe deuterating, And could cause it to overheat...or run on the H side, which isnt letting the air though the Rad fins to cool the coolant, etc.
hocbj23   +1y
Did u put thermostat back in when u took it out?Mazda trucks use a two stage thermostat-one stage opens at 160 deg and the other at 180..They also do not like aftermarket thermos.Replace it and see what happens.
mullet   +1y
I would start by making sure the thermostate is working properly and facing the right direction. And go from there by doing a full radiator flush and if the problem continues, check the water pump and head.
Mike
