Mazda Engine General \  rear end outa line...
views 1210
replies 14
following 7
fanninator   +1y
ok my rear is outa line....WAY. i had to drive over a manhole and i thought i was high enough to clear it but wasnt. heres my result. also to fix this just loosen the shock mounts and scoot it back into place then bolter back down right? thanks -bf
://i29.photobucket.com/albums/c275/bfannin/MVC-030F.
mark   +1y
hey bro jack it up and take a picture of it underneath, we'd be able to help you out a little better that way. for all we know, the axle could just be knocked out of the alignment pin and is an easy fix
fanninator   +1y
well do u just want various pics or spcaific of what. thanks -bf
hocbj23   +1y
Put truck on a hard level surface.Center the steering wheel.Take a tape measure and measure distance between the center of your front wheels and the center of your rear wheels on each side.Loosen your u-bolts holding axle in place and see if u can center ur rear axle that way.Retighten bolts.I would check tires and wheels cause if u hit that hard u probably have warped a wheel and broken a belt in ur tire.Have truck aligned at first opportunity.
89b2200   +1y
There is a good possibility that the leaf spring center bolt/pin was sheared off as Mark stated and pushed the axle back on the driver side.
You will need a new leaf spring center bolt.
Jack it up, take the wheel off, take out the axle u-bolts and you will see that the center bolt has been sheared.
nytrdr24   +1y
^^^^what he said....... sheared bolt, hopefully the rim isn't bent.....
baggedb22   +1y
good reason to get rid of those snow tires=) but that sucks man, 4 link it=)
slammed83mazda   +1y
yep yep yep, now u just gotta bag it haha
fanninator   +1y
haha yeah. snow tire...street tire...slicks...a/t....mudder...lo pro...they all do the same job, some just aint near as nice lookin as others haha. funny thing is i wasnt doin over 10, i donno, i didnt notice it had moved till today. i dont think i bent a rim or anything but ill jacker up n rip some shit out on wed. thanks for all the help yall. ill get back 2 ya. -bf
slammed83mazda   +1y
does it feel like its pulling to the right or left any?
