Well my radiator decided to take a crap and start to leak, radiator shop says I need a new one. So a buddy of mine has a 4x4 radiator that he said I could have. Here's my question is the 4x4 radiator the same exact radiator I have in my truck (1988 b2200 2wd)? Thanks LeDevil
bagged89mazda
SHOULD BE but double check - take measurements of your radiator and compare them to the measurements of the 4x4 i don't honestly thinkg it wouldn't . cause everything on our trucks is basically interchangable except 4x4 differential and transfer case . all the 86-93'S are interchangeable . SAME plate forum.
nytrdr24
the b2200's & b2600's have different radiator supports which allows for the size difference between the three radiators. the b2200's have two radiators, one for a manual tranny; 1 row core, and another for the auto tranny; 2-row core, either will fit in a b2200 truck, i've got a new one for an auto to put with my engine when it gets back it will cool it better than the 1-row core original. the b2600's radiators are a little longer & taller than the b2200's, and i think they are all two row cored radiators. you can put a b2600 radiator in a b2200, but you won't be using the factory mounting points or hoses. i gave $125 for my new one shipped from
