Bell housing question
madmazda
The FE3 is a tranny out of a mx6. I believe is does bolt right up to b2000 and b2200 tranny bellhousing for rwd applications? correct me if im wrong.
midnightmike's avatar
midnightmike
yes
slammed83mazda's avatar
slammed83mazda
does that go for 1983 mazda b-2000s as well
madmazda
Ok, and the Bellhousing for the 83-84 b2000 are interchangable with 86-93...so what does that tell me.
slammed83mazda
what about the tailshaft on the fe3? is it the same as the 83 mazda, cause i do no the tail shafts on 86-93 mazdas are bigger than mine my 83
nytrdr24's avatar
nytrdr24
actually the fe3 is the mazda engine from a 95-02 kia sportage, 79-84 mazda b2000's had ma engines, 85-87 mazda b2000's had fe engines, 87-93 b2200's had f2 engines, not sure of the tranny designations, but i know that the fe & f2's use the same bellhousings, i think that the ma engines are different, i know that the tranny's are. now the 88-92 mx6's had the same f2 engine as the b2200's so those trannys should be interchangeable, atleast should bolt to the engine, i don't know about the tailshaft & if it is adaptable to our driveshafts....you can use a series 4 tranny from 86-88 non turbo rx-7 or series 5 tranny from 89-91 non turbo rx-7's & the bellhousing from a tranny out of a 86-93 truck.
hope this helps..
slammed83mazda
awsome thanks man, only thing i was worried about was the tail shaft but this information helped me alot, i could always get a new shaft made
Post was last edited on Jul 29, 2006 06:30. Edited 1 time.
nytrdr24's avatar
nytrdr24
actually i don't think this will work with your engine slammed83 since it is an ma block & your trannys input shaft is shorter than that of the 86-93 trucks or the rx-7's (per info from mazdatrucking.com)......they will work with a fe or f2 block tho...sorry....& you would be hard pressed to get some one to make a new tail shaft for the tranny as that is actually a part of it.....if you want to swap to a newer tranny you'll probably have to swap out to a newer engine & tranny combo, then have a driveshaft made for that application, which i think would be a kool setup in the older bodystyle trucks like yours!!
slammed83mazda
thank you sir.
i was actually thinking about doing a 86-93 motor swap and the stock tranny on them and the driveshaft and getting the rear end to cause there geared better than mine.
parts would be easier and such but i need to hear the engine run and tahts gonna be the problem for me with junkyards around here
madmazda
Hmm, that would be an idea!
kia swap
last post by Brody +1y
51
