Mazda Engine General \  need help
need help
views 553
replies 3
lowmaz   +1y
I need anyone in GA's help my motor went out and i have a 91 Explorer with the 4.0 v6 with a 5spd tranny i want to swap in my Mazda B2200 and I am not the best a working on motors because i dont know shit about them. So if there is anyone out there in GA that has the time or the space that could help me i would very thankful.
2fine89   +1y
that would be a pretty good swap - lots a get up and go in those 4.0's
framedragger2   +1y
its a fairly smiple job, all you need to do is just make some motor mounts/ tranny mounts, get the brain and wiring harness. and get a drive shaft cut to fit. thats about it.
limequat   +1y
That's a good start:
Custom mounts
Custom cross-member
Custom driveshaft
Custom radiator, heater hoses
A/C lines?
P/S lines?
Exhaust
Fuel lines
Fuel pump
Baffled gas tank
Will the clutch master push enough fluid to actuate the clutch? Custom M/C?
Is the speedo cable driven? Custom cable? Custom electric speedo?
Cruise?
Throttle cable
ABS?
Alternator hook ups
Starter hook ups
Instumentation hook ups or custom gauges
Does the shifter line up? Custom shifter/console?
Engine swaps are PITA. Do it!
