Check engine light
Check engine light
S(
solow93 (ryan)
Does any body no how to rest the check engine light I thought I heard some one say about unpluging something under the dash and plug it back in and it should rest it. But I not sure so if any one no's anythng let me no.
Solow________________________.
hocbj23
Unplug the socket from the check engine lite receptical, turn it over 180 degrees and replug it.Lite should go out.Next time it comes on reverse the process.BJ
midnightmike's avatar
midnightmike
theres a 1 wire plug above the fuse box with another 1 wire plug thats dead, unplug the one and plug it into the other, one should be brown, if i remember correctly
nonamedsomebody's avatar
nonamedsomebody
Some b series have a little switch behind the glove box to the right that you hold down for five seconds or so, That should reset it. I think it was only on the 1980-89 mazda
F
frocashmoney24
take the bulb right out...
mullet
If you look under the dash by the steering coloumn there will be two plugs plugged into each other.. and another plug tapped up to a set of wires. Unplug the two, and plug the taped up third into the one heading to the fuse box.
Mike
S(
solow93 (ryan)
Thanks guys for all the help I just ended up taking the bulb out.
kia swap
last post by Brody +1y
51
