Mazda Engine General \  Vacuum leak between carb & manifold in 86 B2000
views 1299
replies 8
following 2
lalunette   +1y
Hi all !!
I have a vacuum leak between my carb & manifold. I have put in a new gasket but it is still happening.
The mounting surfaces look clean and are not scored.
Is there something I'm missing?
Do I need to add some kind of gasket goo ???
Thx for your input.
hocbj23   +1y
Gasket between carb and manifold is about 3/8 inch thick stock. Is replacement the same?U should not have to use sealant on thst gasket as it is designed to compress and seal when torqued. Did u get torque spec for carb bolts and torque accordingly?Do u know where leak is?use a NON-FLAMMABLE aerosol or soapy water and mist around base of carb with engine running.May be able to localize leak this way.BJ
lalunette   +1y
My local mechanic (the one that did the safety on the truck back in April) had a look at it this morning and located the leak. I will be changing both the mounting plate and the gasket between the carb and the manifold this weekend.
Thx for your help.
hocbj23   +1y
I will get torque specs for u this evening and post them early in the am if u still need them. Your mechanic may already know them.Hope the new gasket and plate work-keep us posted. BJ
lalunette   +1y
Thank you !!
I will definitely need the torque specs. I intend to change the gaskets this weekend.
hocbj23   +1y
14-19 pounds.BJ
lalunette   +1y
Merci-Gracias-Thx !!
Bought myself a torque wrench today... my first one EVER !!!
Oh joy, oh bliss... a new toy !!
hocbj23   +1y
Damn. What would you do if someone handed u an air wrench.Lol. Just kidding.Enjoy the new toy.BJ
lalunette   +1y
Hell, you should of seen me at my brother's place last week !!!
He has a huge air compressor and a professional grade air wrench !!!
I bought an old skido trailer (8 feet long by 6 feet wide) for $100 and transformed it into a 14 feet long by 6 feet wide Jon boat trailer. I had a great time dissassembling most bolts on the trailer with the air wrench
